BUG
Parallel Processing does not work in ArcMap with 64-bit Background Geoprocessing enabled
Last Published: January 27, 2023
Cause
This is a known limitation/as designed behavior, and has been reported as the following defect:
NIM087308 Parallel Processing does not work with 64-bit Background Geoprocessing at ArcMap (ArcGIS for Desktop)
Workaround
Parallel processing is not supported in 64-bit Background Geoprocessing. Users can either run tools that support parallel processing with 32-bit Background Processing set up in ArcMap or migrate to ArcGIS Pro.
To make sure that parallel processing works in ArcMap (ArcGIS Desktop), follow these steps:
  1. Go to the Geoprocessing tab, and click Geoprocessing Options.
[O-Image]
  1. In the Geoprocessing Options dialog, uncheck Enable Background Processing.
[O-Image]
Article ID:000020455
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
