ERROR
Failed to update domain: ERROR: Domain is used beyond the scope of the service
Error Message
When modifying the coded values of the domain using the ArcGIS Solutions Deployment tool, the Update Domain process fails with the following error message:
Error:
Failed to update domain: ERROR: Domain is used beyond the scope of the service.
Failed to update domain: ERROR: Domain is used beyond the scope of the service. Failed to execute (Update Domain)
Cause
This error occurs when the hosting server (Portal for ArcGIS or ArcGIS Online) already contains a hosted feature layer with the same domain name.
Solution or Workaround
Change the domain name when modifying the coded values.
Change the domain name.
For more information on the issue and related workflow, refer to the following GeoNet thread: Update Definition with JSON - cannot find the file to modify.
Article ID:000020198
Software:
  • ArcGIS Online
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
