Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
ArcGIS Desktop crashes after applying the TLS 1.2 patch
This is caused by a version of .NET that does not support TLS 1.2 connections. For ArcGIS 10.2.1 through 10.3.1, this set of releases uses an earlier version of Microsoft .NET that does not support TLS 1.2.
Esri recommends upgrading the system to use .NET4. If this is not feasible, follow the instructions in Part D of the article:
How To: Configure Windows to use TLS 1.2 for ArcGIS Desktop.
Last Published : 2/14/2019
Article ID: 000020128
Software: ArcMap 10.3.1, 10.3
