Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
Using a Spatial Analyst tool, such as 'Hillshade', returns a Tool Not Licensed dialog box with the following error message:
Unable to execute the selected tool. You do not have the necessary license to execute the selected tool. ERROR 010096: There is no Spatial Analyst license currently available or enabled.
There are three possible causes for this error message:
Perform the solutions below in the order they are presented.
Verify that the Spatial Analyst extension is authorized
Enable the extension in ArcMap
Enable the extension in ArcCatalog
Note: Certain functionalities in ArcMap, such as ModelBuilder, require the extension enabled in ArcCatalog.
