BUG
Unable to run Tapestry Profile report in Target Marketing as US Household Tapestry Profile errors when selected as the base and which also affects the US Adults Tapestry Profile base when used as base
Last Published: July 21, 2023
An error is returned when US Household Tapestry Profile or US Adult Tapestry Profile are selected as base while setting up the Tapestry Profile Report.
Cause
The Profile.xml file associated with each of these base US Profiles incorrectly references the Business Analyst datasets release year. The Segmentation System value should be set to '2014'.
Workaround
To resolve the issue, two files in the Segmentation Profiles folder must be updated for the Esri US 2018 Data Update.
  1. Download the Segmentation Profiles folder, which contains updated XML files.
  2. Overwrite the Segmentation Profiles folder within the 2018 dataset path. For default installations, the folder should be copied to:
    C:\ArcGIS\Business Analyst\US_2018\Datasets\
This issue also affects the Esri 2017 dataset. If this dataset is installed, download the 2017 Segmentation Profiles folder and overwrite the existing folder within the following path: C:\ArcGIS\Business Analyst\US_2017\Datasets\
Once the Profile.xml files have been updated the Tapestry Profile report can be run with either US Households Tapestry Profile, or US Adults Tapestry Profile applied as a base.
Article ID:000019920
Software:
  • More Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
