Be The First To Get Support Updates
Want to know about the latest technical content and software updates?
Problem: Unable to add multipoint features in an ArcGIS Online application
When using the Edit button in ArcGIS Online Map Viewer, or using the Edit or Smart Editor widgets in Web AppBuilder for ArcGIS, multipoint features are not added to a feature service.
Cause
This is a known limitation. Adding multipoint features in the ArcGIS Online application is not supported. For more information, refer to BUG-000104054.
Solution or Workaround
To resolve this issue, convert the multipoint feature class to a single-point feature class.
- In ArcMap or ArcGIS Pro, use the Multipart to Singlepart tool. The Solution section in the technical article, Problem: The Intersect tool generates a multipoint feature class describes how to use the tool.
- After the multipoint features are converted to single-points, publish the single-point feature class to ArcGIS Online following the steps described in ArcGIS Online Help: Publish from ArcMap.
Related Information
- ArcGIS Pro Help: Multipart To Singlepart
- ArcMap: Feature class basics
- ArcGIS Pro Help: Feature class basics
- Web AppBuilder for ArcGIS Help: Edit widget
- Web AppBuilder for ArcGIS Help: Smart Editor widget
Last Published: 2/20/2019
Article ID: 000019837
