PROBLEM
When georeferencing a raster image using Update Georeference in ArcMap, the image moves to a different location.
Note: BUG-000111060 appears to be specific to ArcMap 10.5.1 and is not reproducible at version 10.6.
Use one of the following options to resolve the issue:
Rectify the raster file
Rectify the raster file. If this does not work, uncheck the Use world file to define the coordinates of the raster option. Follow the steps below:
Remove the image from the map
Remove the image from the map and delete the associated .tfwx, tif.aux.xml, and tif.ovr files. Georeference the .tif file and click Update Georeferencing. This generates new associated .tfwx, tif.aux.xml, and tif.ovr files.
Get help from ArcGIS experts
Download the Esri Support App
