HOW TO
In some cases, it is favorable to create a web map using a script, as it can be programmed for multiple web maps. Using the definition specified in a JSON file, the gis.content.add function in ArcGIS API for Python version 2.3 and prior can be used to create the web map.
Web maps can be created from a JSON file representation using the gis.content.add function in the GIS module. There are two ways to do :
Note: Defining the JSON description is a longer process. However, it gives the user the ability to modify the JSON representation of the script.
The steps below describe how to create a web map from a JSON file by reading it using the json module.
Import the necessary modules.
from arcgis.gis import GIS from arcgis.mapping import WebMap import json
gis = GIS('https://<machine>.<domain>/<web adaptor name>/home', 'username', 'password', verify_cert=False)
print ('Connected')
with open('/home/jupyter/test2.json') as json_data:
	data = json.load(json_data)
item_properties_dict = {"type": "Web Map","title": "Test Map","tags": ["test","test1","test2"],"snippet":"This is a snippet", "text":data}
newmap = gis.content.add(item_properties = item_properties_dict)
newmap
The following shows the full script:
import json
print ('Connected')
newmap
The steps below describe how to create a web map by defining the JSON description in the script.
data = {
	"operationalLayers": [{
			"id": "layer_2382",
			"layerType": "ArcGISMapServiceLayer",
			"url": "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer",
			"visibility": True,
			"opacity": 1,
			"title": "Census Data",
			"layers": [{
					"id": 0,
					"layerDefinition": {
						"source": {
							"type": "mapLayer",
							"mapLayerId": 0
					"name": "Census Block Points",
					"minScale": 99999.99998945338,
					"maxScale": 0,
					"parentLayerId": -1,
					"defaultVisibility": True
					"id": 1,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 1
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"color": [0, 0, 0, 0],
									"outline": {
										"color": [230, 230, 0, 255],
										"width": 0.39975000000000005,
										"type": "esriSLS",
										"style": "esriSLSSolid"
									"type": "esriSFS",
									"style": "esriSFSSolid"
					"name": "Census Block Group",
					"minScale": 1000000,
					"maxScale": 0,
					"id": 2,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 2
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"outline": {
										"width": 0.5625,
										"type": "esriSLS",
									"type": "esriSFS",
					"name": "Detailed Counties",
					"minScale": 0,
					"maxScale": 0,
					"id": 3,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 3
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"outline": {
										"width": 2,
										"type": "esriSLS",
									"type": "esriSFS",
					"name": "states",
					"minScale": 0,
					"maxScale": 0,
	"baseMap": {
		"baseMapLayers": [{
				"id": "labels",
				"layerType": "ArcGISTiledMapServiceLayer",
				"url": "https://services.arcgisonline.com/arcgis/rest/services/Canvas/World_Dark_Gray_Base/MapServer",
				"visibility": True,
				"opacity": 1,
				"title": "World_Dark_Gray_Base"
				"id": "base",
				"url": "https://services.arcgisonline.com/arcgis/rest/services/Canvas/World_Dark_Gray_Reference/MapServer",
				"visibility": True,
				"opacity": 1,
				"title": "World_Dark_Gray_Reference"
		"title": "Basemap"
	"spatialReference": {
		"wkid": 102100,
		"latestWkid": 3857
	"authoringApp": "WebMapViewer",
	"authoringAppVersion": "10.6.1",
	"version": "2.11"
newmap
print ('Connected')
data = {
			"id": "layer_2382",
			"visibility": True,
			"opacity": 1,
			"layers": [{
					"id": 0,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 0
					"maxScale": 0,
					"id": 1,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 1
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"outline": {
										"type": "esriSLS",
									"type": "esriSFS",
					"maxScale": 0,
					"id": 2,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 2
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"outline": {
										"width": 0.5625,
										"type": "esriSLS",
									"type": "esriSFS",
					"minScale": 0,
					"maxScale": 0,
					"id": 3,
						"source": {
							"type": "mapLayer",
							"mapLayerId": 3
						"drawingInfo": {
							"renderer": {
								"type": "simple",
								"label": "",
								"description": "",
								"symbol": {
									"outline": {
										"width": 2,
										"type": "esriSLS",
									"type": "esriSFS",
					"name": "states",
					"minScale": 0,
					"maxScale": 0,
	"baseMap": {
		"baseMapLayers": [{
				"id": "labels",
				"visibility": True,
				"opacity": 1,
				"id": "base",
				"visibility": True,
				"opacity": 1,
		"title": "Basemap"
		"wkid": 102100,
		"latestWkid": 3857
	"version": "2.11"
newmap
The image below shows the newly created web map.
Article ID: 000019701
Get help from ArcGIS experts
Start chatting now
