English
Error: This functionality is not available without the ArcGIS Pro Licensing Service being installed
Error Message
In some instances, attempts to authorize ArcGIS Pro Single Use licensing fails and the following error is returned:
Error:
This functionality is not available without the ArcGIS Pro Licensing Service being installed.
The image of the Authorization error.
Cause
In some cases, the ArcGIS Pro installation is completed and no error message is returned. However, the ArcGIS Pro Licensing Service installation process is left out.
Without the ArcGIS Pro Licensing Service, Single Use licensing authorization is not possible and its functions may also be unavailable.
Solution or Workaround
A manual installation of ArcGIS Pro Licensing Service is required to fix this issue. To do so:
  1. Navigate to the following folder location:
C:\Program Files\ArcGIS\Pro\Resources\ArcGIS Pro Licensing Service
  1. Run the ProLS.msi file.
Related Information
