Is This Content Helpful?
How can we make this better? Please provide as much detail as possible.
Contact our Support Team
In some instances, users may want to customize the image size in the ArcGIS Online pop-up window. Although the image is displayed based on its default size when configured using Image Options, it is possible to customize the image size by embedding a field containing customized HTML codes using Text Options.
Follow the steps below to modify the image size in the ArcGIS Pro pop-up window:
Note: Image size parameters customized are the image width and the image height.
<img src="Image URL" style="width:100px;height:100px;">
<img src="Image URL" width="100" height="100"/>
The image below shows the new field with the list of HTML codes containing the image URLs and customized image sizes.
Note: • When using Image to select the field containing HTML codes, the image fails to appear in the pop-up window. • Configuring the Source URL section in Image Options only allows the selection of a field, hence only one image is displayed. • Using Image Options, it is not possible to select a few fields to concatenate multiple images in the pop-up window.![]()
Last Published: 12/31/2018
Article ID: 000019312
Software: ArcGIS Pro 2.2.4, 2.2.3, 2.2.2, 2.2.1, 2.2
