ERROR
Unable to auto-detect delimiting character; defaulted to ','
Error Message
A survey using the pulldata() function to obtain the information saved in a CSV file loads successfully in the Survey 123 for ArcGIS Connect but returns the following error in the Survey 123 for ArcGIS Web form:
Error:
Error: Initialing Form...
Error message
Cause
The error is caused by a null line in the CSV file. When the CSV file is opened in a text editor such as Notepad ++, an extra null line can be seen without any information or data available, as displayed in the image below. The Survey 123 for ArcGIS Field app ignores the null line. However, the Survey 123 for ArcGIS Web form is sensitive to the null line.
Null line
Solution or Workaround
To resolve this issue, open the CSV file in a text editor such as Notepad ++ and delete the null line. Save the contents. Publish the survey again using the Survey 123 for ArcGIS Web form. For more detailed steps, refer to Publish your survey.
Article ID:000019311
Software:
  • ArcGIS Survey123 Field App iOS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
