PROBLEM
A print service published to ArcGIS Server running on Red Hat Enterprise Linux does not display the intended output to all file formats. For example, the intended output may display all components of a template is appears as intended when the output format is set to JPEG or PNG, but it appears blank for the PDF format.
Linux relies on certain packages to be installed to fulfill certain print jobs on the machine. In this case, for ArcGIS Server print services, the 'python-cups' package is required to allow print services to display the components as intended.
This issue can be resolved by using the Linux yum command to install the python-cups package via the Linux command line.
yum install python-cups
Get help from ArcGIS experts
Download the Esri Support App
