Frequently asked question
Are Print Preview and Tile Map to Printer Paper options available in ArcGIS Pro?
Answer
In ArcMap, the Print Preview option is useful to view map layouts before printing. The Tile Map to Printer Paper option helps to organize and customize the tiling of map layouts. Large map layouts are usually tiled to print successfully without any missing content, and can be previewed as a precaution to avoid printing mistakes. ArcMap has the functionality to customize the tiling of large map layouts and provide a preview pane of the tiles in the Print window. While these options are available in ArcMap, ArcGIS Pro does not have as many tiling options or a user-friendly preview pane. The image below shows the printing options available in ArcGIS Pro.
Print option in ArcGIS Pro
As a workaround, export the map layouts to PDF using Adobe Acrobat. Tile and print the map layouts in Adobe Acrobat. For more information, refer to ArcGIS Pro Web Help: Share a map or layout as a vector format (EMF, EPS, PDF, SVG, SVGZ).
Article ID:000019191
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
