ERROR
Error executing tool. PublishServiceDefinition ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details.
Last Published: January 27, 2024
Error Message
When attempting to publish a service referencing an enterprise database or geodatabase in ArcGIS Server 10.5.0, an error similar to the following is returned:
Error:
In certain cases, existing services that use these connections may work properly, and data stores may validate successfully.
Cause
The 'dsconnections.lst' file is not present in the following directories:
C:\arcgisserver\config-store\data
C:\Program Files\ArcGIS\Server\DatabaseSupport
This file is not generated when the 'Validate All' command is run via ArcGIS Server Manager. This issue is caused by a defective patch, the 'ArcGIS Server Geoprocessing Service Startup Patch' for 10.5.0.
Solution or Workaround
To circumvent the issue, follow the steps outlined below:
  1. Remove the previously installed Geoprocessing Service Startup patch.
  2. Download and install the updated patch: ArcGIS Server Geoprocessing Service Startup Patch.
  3. Log in to ArcGIS Server Manager. Navigate to Site > GIS Server > Data Stores. Click Validate All.
    Image of the ArcGIS Server Manager Data Stores page.
Article ID:000019106
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
