HOW TO
Convert GeoEvent logs to Excel and summarize unique messages by count using Python
Summary
In some cases, the GeoEvent log files are converted to Excel for multiple purposes. For example, for filtering different types of errors, or to create a count summary based on unique error messages.
Procedure
The following steps demonstrate how to convert GeoEvent logs to Excel and summarize unique message by count using a Python script.
The script creates two files, analyzed and message_count.
  1. Import the required libraries.
import os
import pandas as pd
  1. Define the log file directory.
log_dir = r'C:\Program Files\ArcGIS\Server\GeoEvent\data\log'
log_path = [os.path.join(log_dir, log_file) for log_file in os.listdir(log_dir)]
  1. Iterate the conversion to Excel process for each log in the directory.
i=1
for path in log_path:
    if path.endswith('karaf.log'):
        df = pd.read_table(path,
                           sep='|',
                           header=None,
                           names=['level', 'unknown1', 'unknown2','logger', 'message'],
                           parse_dates=True, error_bad_lines = False, warn_bad_lines = True)
        df.to_excel(os.path.join(log_dir, 'analyzed{}.xlsx'.format
  1. Create the summarize count.
count = df['message'].value_counts()
count.to_excel(os.path.join(log_dir, 'message_count.xlsx'))
The following code sample demonstrates a full working script:
import os
import pandas as pd
# Define Log Directory
#for log_file in os.listdir(log_dir):
    #log_path = os.path.join(log_dir, log_file)
    #print(log_path)
# Convert to Excel
i=1
                           sep='|',
                           header=None,
        df.to_excel(os.path.join(log_dir, 'analyzed{}.xlsx'.format(i)))
        i+=1
# Summarize by count
The code can be used as a standalone script. To do so, copy the full script into a text editor, for example, Notepad++, and save the file as a .py file. To run the code, right-click the .py file and select Edit with IDLE > Select Run > Run Module.
Article ID:000018954
Software:
  • ArcGIS Monitor Server
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
