PROBLEM
When configuring or working with a Crowdsource Manager web app, the Comments tab does not appear in the attribute information when selecting a record.
The Comments tab can be seen in the attribute information of a record only when related records are used in the schema of the service that the Crowdsource app is based on.
The workflow to use Comments through a related table with a Crowdsource app is described in the following resource: Crowdsource Reporter: Create layers - Enable or disable comments
Add the Comments tab in the Crowdsource Manager web application by following the steps below:
Note: To add the Media tab, the feature must have at least one attachment. Follow the same procedure described and select Media in the default selected tab.
Get help from ArcGIS experts
Download the Esri Support App
