ERROR
Warning: This survey has already been published. The existing data service is not compatible with the survey - (Table <table name> not found)
Last Published: May 9, 2022
Error Message
When republishing a survey from ArcGIS Survey123 Connect, the following error message is returned:
Error:
The existing data service is not compatible with the survey - (Table <table name> not found).
Screenshot of error message.
Cause
The form ID of the republished survey does not match the hosted feature layer name of the published survey.
Solution or Workaround
Before republishing, ensure that the value in the form_id column of the republished XLSForm has the exact name of the published hosted feature layer. The name of the published hosted feature layer is on the item details page of the survey.
Screenshot of the item details with the hosted feature layer name highlighted.
The form_id column is on the Settings tab of the XLSForm.
Screenshot of the Settings tab with the form ID highlighted.
Article ID:000018614
Software:
  • ArcGIS Survey123 Connect
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
