PROBLEM
Switching to a custom basemap zooms to the basemap full extent in Portal for ArcGIS Map Viewer
In Portal for ArcGIS Map Viewer, switching to a custom basemap causes the map to zoom to the full extent of the basemap. In some cases, the data in the map is no longer visible as the map extent is changed to the basemap's full extent.
Cause
This issue occurs because the custom basemap extent is set to a specific area and does not cover the globe.
Solution or Workaround
Set the extent of the custom basemap to cover the globe. To achieve this, change the extent of the custom basemap web map according to the following coordinates:
  • Left: -180
  • Right: 180
  • Top: 90
  • Bottom: -90
Click OK to save the extent settings and reflect the changes to the custom basemap.
Article ID:000018512
Software:
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
