PROBLEM
Uploading a file geodatabase to ArcGIS Online returns 'Error processing table data'
The following message is returned after uploading a zipped folder to Content in ArcGIS Online.
Error:
Error Processing table data - check file format, supported data types and data license.
Screenshot of the error message.
Cause
The file uploaded to ArcGIS Online is a higher-level folder that contains the file geodatabase folder, and is not directly the zipped file geodatabase itself.
Solution or Workaround
The zipped folder name must be written in the format, [name].gdb.zip. In addition, the title in ArcGIS cannot contain special characters (such as ".gdb").
Article ID:000018498
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
