Frequently asked question
Is it possible to remove outlying elevation values from a LAS file?
Answer
No, it is not possible to remove elevation points from the LAS file. However, it is possible to classify the points as noise and filter the data out. Using the Classify LAS Noise tool in ArcGIS Pro to classify the points as noise, follow the steps below.
The Classify LAS Noise tool requires a 3D Analyst license. For more information, refer to Classify LAS Noise.
  1. Right-click the point feature (LAS) layer containing the noise > Properties.
  2. Select LAS Filter in the left pane, uncheck the 7 Low Noise check box, and click OK.
    Uncheck the 7 Low Noise check box.
Article ID:000018276
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
