Frequently asked question
Can null values be excluded from the Pie Chart widget display output in Operations Dashboard for ArcGIS?
Answer
Yes, null values can be excluded from the Pie Chart widget display output in Operations Dashboard for ArcGIS. All datasets are unique, and in some instances, some fields require null values. The following workflow describes how to exclude fields containing null values. This only excludes the fields containing the null values, and not the entire record.
  1. On the dashboard, hover over the upper left corner of the element to display the menu.
    Image of the context menu
  2. Select Configure and click the Data tab.
  3. Click the +Filter button to add a filter.
    Image of the Data tab
  4. To filter and exclude the null values, use the following example:
    <field name> include <values>
    For more information on working with filters, refer to ArcGIS Help: Filter data.
  5. Click Done.
Article ID:000018273
Software:
  • Mobile Applications
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
