PROBLEM
The flow direction shows indeterminate in a versioned geodatabase
Last Published: March 8, 2021
In the default version, the flow direction arrows show up. However, when viewing the secondary version, the flow direction shows indeterminate.
Cause
The flow direction shows indeterminate because the primary and secondary versions are not reconciled.
Solution or Workaround
Reconcile and post changes from the secondary version to default and the flow direction is shown. Reconciling versions and posting changes requires an ArcGIS Desktop Standard or Advanced license. For more information on reconciling versions and posting changes in ArcMap, refer to: ArcMap: Reconciling a version and ArcMap: Posting changes.
Article ID:000018147
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
