PROBLEM
Images with the same projection do not overlap in ArcMap
In some instances, raster images with the same projection do not overlap in ArcMap.
Cause
This issue may occur if one or more of the raster images have different extents.
The extent of the first image.
The extent of the second image.
Solution or Workaround
Check which raster image has the wrong extent and georeference the image. For more information, refer to How To: Georeference an image to align with other data.
Article ID:000018120
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
