PROBLEM
The Spatiotemporal Big Data Stores page in GeoEvent Manager is empty
After configuring the spatiotemporal big data store with the hosting server, the Manage Spatiotemporal Big Data Stores tab in GeoEvent Manager is empty.
Cause
This is expected behavior. The Spatiotemporal Big Data Stores page does not populate the content until an output connector such as the 'Add a Feature to a Spatiotemporal Big Data Store' or 'Update a Feature in a Spatiotemporal Big Data Store' with a big data store map or feature service is published or created.
Solution or Workaround
Create an output connector with a map or feature service that uses the spatiotemporal big data store to populate the Manage Spatiotemporal Big Data Stores tab with the expected Data Source, Map Services, and Feature Services information.
User-added image
Note: Content is also populated if a user adds a data source directly from this page.
Article ID:000018014
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
