PROBLEM
An image appears on the form preview in the ArcGIS Survey123 Connect application but does not appear on the published survey form
Last Published: May 11, 2022
After adding an image question in the ArcGIS Survey123 Connect application, the image appears on the form preview, but does not appear on the published survey in the ArcGIS Survey123 web app.
The published survey form does not display the image
Cause
This issue may occur when:
The file name with spaces and special characters in the .xlsx sheet
  • The image file name in the .xlsx sheet does not match the file name in the media folder.
Solution or Workaround
Depending on the cause, use one of the following solutions to resolve this issue, and republish the survey.
Updating and republishing the survey does not affect the existing data.
Remove the spaces and special characters from the image name in the media folder
  1. In the ArcGIS Survey123 Connect application, click the survey content folder.
The survey content folder in ArcGIS Survey123 Connect
  1. Open the media folder, and locate the image.
The media folder in Windows Explorer.
  1. Remove the spaces and special characters from the image name.
The image is renamed without spaces and special characters
  1. Navigate to the .xlsx form, and insert the new image name.
The .xlsx after replacing the image file name
  1. Save the .xlsx form.
  2. Navigate to ArcGIS Survey123 Connect, and republish the survey.
The Publish icon in the ArcGIS Survey123 Connect application to republish the survey.
Copy the file name in the media folder and paste it in the .xlsx sheet
  1. In the media folder, right-click the file name, and click Properties.
  2. Copy the file name, and click OK to close the Properties window.
Copying the file name in the Properties window
  1. Paste the file name in the media::image column in the .xlsx sheet.
  2. Save the .xlsx sheet, and republish the survey form.
To view the published survey form, click the Show online survey item icon The Show online survey item icon. The image now appears below the question.
The image appears in the published survey form
Article ID: 000017991
Software:
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
