FAQ: Is it possible to create sites from a heat map in the Business Analyst web app?
Question
Answer
No, it is not possible to create sites from a heat map created in the Business Analyst web app because the heat map is just a dynamic symbology option for the point dataset and the heat map polygons are not selectable features. A possible workaround is to create the heat map in ArcGIS Online using the Calculate Density tool and add this map to the Business Analyst web app to create sites.
In ArcGIS Online, add the desired point data to create the heat map. Refer to the following document on how to add items to ArcGIS Online: Add items.
Open the added feature layer in the ArcGIS Online map viewer.
In the My Content tab, search for the added feature layer, and click the ellipsis icon > Open in Map Viewer.
Run the Calculate Density tool to create the heat map.
