ERROR
ArcMap crashes when trying to add a basemap, and returns Serious Application Error message
Last Published: January 27, 2022
Error Message
When adding a basemap to the current ArcMap session, the application crashes and the Serious Application Error message is returned.
Cause
There are many possible causes for this issue and the solutions range from renaming the ArcMap folder to a full uninstall/reinstall of the application.
However, one possible cause is an outdated driver for the Graphics Processing Unit (GPU), also known as the video card or graphics card.
Solution or Workaround
Consider the following workaround. If it resolves the issue, to resolve it permanently, consider updating the GPU drivers from the manufacturer, for example, Nvidia, AMD, Intel, etc., or from the manufacturer of the laptop, if it is a laptop PC.
The crash may indicate a failure to initialize the hardware blender for basemap layers. This usually is caused by a failure of the GPU driver on the machine. As such, Esri can’t make any changes that fix it – the problem is occurring in the driver for the GPU.
Turn off hardware acceleration for basemap layers
  1. Go to Customize> ArcMap Options, and click the Data View tab.
  2. Uncheck the box for Enable hardware acceleration for supported layers, and click OK.
When starting a basemap layer for the first time, such as when adding a basemap from ArcGIS Online, a prompt to enable hardware acceleration displays. Check the box for don’t show this dialog again, and click No.
Article ID:000017961
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
