Frequently asked question
Is it possible to label an event layer?
Answer
Yes, however event layers are only temporary, and do not persist after an editing session. To make labels permanent in an event layer, the event layer must be converted to an editable feature class such as a shapefile before adding the labels. The instructions provided below describe how to convert an event layer into a shapefile and create a label expression based on multiple fields:
  1. In ArcMap, export the event layer as a shapefile. For more information, refer to How To: Export a layer to a shapefile in ArcMap.
  2. When prompted to add the exported data as a layer to the map, click Yes.
    Screenshot of the prompt with Yes highlighted.
  3. Right-click on the exported layer > Properties.
  4. In the Layer Properties dialog window, select the Labels tab.
  5. In the Labels tab, click Expression.
    Screenshot of the Labels tab with Expression highlighted.
  6. Under the Fields section, select the field to be used as the label and click Append.
    Screenshot of Label Expression with Append highlighted.
  7. Repeat Step 6 for each field to be appended as the label.
  8. When all the fields have been appended for the label, click Verify.
    Screenshot of Label Expression with Verify highlighted.
  9. If the expression is valid, click OK at the Expression Verification and Label Expression dialog boxes.
  10. In the Layer Properties dialog, click Apply and click OK.
  11. Right-click the layer, and click Label Features. The labels based on the selected fields from the Label Expression appears.
Article ID:000017947
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
