ERROR
Error creating this geodatabase. This application is not licensed to perform this operation
Error Message
With ArcGIS Server Workgroup, a workgroup geodatabase can be created using ArcMap and can be accessed by up to 10 users at a time. In some instances, when creating a workgroup geodatabase, the process fails and returns the following error:
Error:
Cause
The following are possible causes for this issue:
  • The SQL Server instance version is not compatible with the installed ArcGIS version.
  • The SQL Server instance is not authorized with an ArcGIS Server Workgroup license.
Solution or Workaround
Depending on the cause, select one of the options below to resolve this issue:
Article ID:000017831
Software:
  • ArcGIS Desktop 1
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
