Error: 502 Web server received an invalid response while acting as a gateway or proxy server
Error Message
Accessing a web server with not trusted or expired Portal for ArcGIS and/or ArcGIS Server self-signed certificates returns the following error, even if the web server certificate is valid.
Error: Error: 502 Web server received an invalid response while acting as a gateway or proxy server
Cause
A certificate is a digital file that contains information about the identity of the web server. It also contains the encryption technique to use when establishing a secure channel between the web server and the organization. See: Enable HTTPS on your web server
Despite a valid Secure Sockets Layer (SSL) certificate on the web server, the error is returned because the Portal for ArcGIS and ArcGIS Server self-signed certificates have expired.
Note: There are no web adaptors in an Azure Web Geographical Information Systems Cloud Builder deployment. Instead, a URL Rewrite is used, redirecting from a web server URL to HTTPS port 7443 for Portal for ArcGIS, and HTTPS port 6443 for ArcGIS Server.
Solution or Workaround
To circumvent the error, follow the steps below:
- Export the self-signed certificates from Portal for ArcGIS and ArcGIS Server.
- Install these certificates to the server's trusted storage.
- Switch Portal for ArcGIS and ArcGIS Server to use their self-signed certificates.
Related Information
- Import a certificate into the portal
- Enable SSL on your web server
- How To: Export Certificates from ArcGIS Server and Portal for ArcGIS
Last Published: 1/30/2023
Article ID: 000017820
Software: Portal for ArcGIS 11, 10.9.1, 10.9, 10.8.1, 10.8, 10.7.1, 10.7, 10.6.1, 10.6, 10.5.1, 10.5, 10.4.1, 10.4, 10.3.1, 10.3, 10.2.2, 10.2.1, 10.2
