ERROR
Cannot drop index because it does not exist or you do not have permission
Error Message
Attempting to update the layer definition of a hosted feature service through the REST Endpoint, such as adding a domain value, fails and returns the following error:
Error:
Cannot drop index '<index name>' because it does not exist or you do not have permission.
Cause
This error may occur if the Optimized Layer Drawing setting is enabled. This is a setting in the Item Details page for the hosted feature service. For more information on Optimized Layer Drawing, refer to the following help document, ArcGIS Online: Manage hosted feature layers.
Solution or Workaround
Disable the Optimized Layer Drawing setting before updating the layer definition. After updating the layer definition, enable the Optimized Layer Drawing setting again. Follow the steps below to disable the Optimized Layer Drawing setting:
  1. Open the feature layer in ArcGIS Online: Content > My Content tab.
The image of Content &gt; My Content tab.
  1. Click the Settings tab on the Item Details page of the hosted feature layer.
Image of the Settings tab on the opened hosted feature layer.
  1. Scroll to the Optimized Layer Drawing segment. Deselect all options under the Select the layers to optimize section and save the changes.
Image of the Optimized Layer Drawing settings segment.
Article ID:000017646
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
