BUG
The Summary Reports tool cannot be run in ModelBuilder without first manually creating an output folder
When using the Summary Reports tool in a model, the output parameter cannot be set, preventing the model from being run.
Cause
This is because the model requires an existing folder before the output parameter can be set.
User-added image
Workaround
Manually create a folder in the default projects location. Then point to this folder when setting up the model.
Article ID:000017577
Software:
  • ArcGIS Business Analyst Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
