PROBLEM
Cannot install Collector for ArcGIS on a compatible Android device through Google Play
An Android device meets the Android Device Requirements for using Collector for ArcGIS. However, when attempting to install the app, Google Play returns a message stating that Collector for ArcGIS is not compatible with the device.
Cause
Google Play is incorrectly reporting that some compatible devices are not compatible.
Solution or Workaround
If experiencing this issue, install Collector for ArcGIS directly from Esri by following the steps in FAQ: How do I download Collector for ArcGIS without access to Google Play or the Windows Store?
Article ID:000017573
Software:
  • ArcGIS Collector
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
