HOW TO
Upgrading from System Monitor 3.x or 10.5.x can be completed by following the instructions below in the section "Upgrade from System Monitor 3.x or 10.5.x to ArcGIS Monitor".
Upgrading from System Monitor 2.x or 1.x is not supported due to significant design changes. To move to ArcGIS Monitor 10.6, follow the instructions in the section below titled, "Migrate from System Monitor 2.x or 1.x to ArcGIS Monitor."
The monitoring service (.cpj file) can be imported from 3.x in the ArcGIS Monitor 10.6 Administrator. This creates a new Windows service, from which the same credentials working in 3.x can be set, and each counter type that was imported can be tested. After the test is successful, new data for those counters can be collected. If there are any extensions or tasks present, the latest version of the extension from the ArcGIS Monitor Gallery must be installed.
Historical data from the 3.x or 10.5.x database cannot be migrated as it is not supported. If historical data from 3.x or 10.5.x is needed, run the desired reports in the 3.x or 10.5.x version, and then uninstall System Monitor.
As previously stated, upgrading from System Monitor 2.x or 1.x is not supported due to significant design changes. To migrate to ArcGIS Monitor 10.6, perform the following steps.
Article ID: 000017474
Get help from ArcGIS experts
Start chatting now
