English
Problem: Unable to open an ArcGIS Pro annotation feature class in ArcMap
When using ArcMap to open an annotation feature class created in ArcGIS Pro, the following error message is returned:
Error:
Error opening feature class
Unable to create object class extension COM component [annotation feature class name]
An image of the error message.
Cause
This is a known limitation. Annotation feature classes created in or upgraded to ArcGIS Pro are not supported in ArcMap.
Solution or Workaround
To view the annotation in ArcMap, use one of the following options:
The following workarounds allow 'read-only' of the annotations in ArcMap.
Publish the annotation feature class to ArcGIS Online and add the web tile layer to ArcMap
  1. In ArcGIS Pro, publish the annotation feature class as a web tile layer to ArcGIS Online.
    An image of the Share As Web Layer pane.
  2. Open the published tile layer in ArcMap to view the annotations.
    1. In ArcMap, sign in to ArcGIS Online.
    2. Click the Add Data drop-down arrow, and click Add Data From ArcGIS Online.
    3. In the ArcGIS Online dialog box, search for the published annotation tile layer name in the search box.
    4. In the search results, click Add to add the annotation tile layer to ArcMap.
      An image of the ArcGIS Online window.
      The image below shows an annotation tile layer added to ArcMap.
      An image of an annotation tile layer.
Convert the annotation to point features, and label the points using the TextString field in ArcMap
  1. In ArcGIS Pro, convert the annotation to point features using the Feature To Point tool.
    The Feature To Point tool is only available with an ArcGIS Desktop Advanced license.
    1. In the Geoprocessing pane, navigate to Toolboxes > Data Management ToolsFeatures > Feature To Point.
    2. In the Feature To Point pane, select the annotation feature class as the Input Features.
    3. Set a name and location for the Output Feature Class.
    4. Click Run. The annotations are displayed in the TextString field in the point feature class attribute table as shown in the image below.
      An image of the point feature class attribute table.
  2. In ArcMap, add the point feature class to the map, and label the features using the TextString field.
    1. Click the Add Data icon, and browse to the point feature class converted in Step 1.
    2. In the Labeling toolbar, click Label Manager.
    3. In the Label Manager dialog box, check the check box for the point feature class in the Label Classes section, and select TextString for the Label Field.
    4. Optionally, in the Placement Properties section, select Angle by field, and click Rotation to rotate the labels according to the angle of the original annotation.
      An image of the Label Manager dialog box.
    5. In the Rotation dialog box, select the Angle field for Rotate Labels by Angle in this field, and click OK.
      An image of the Rotation dialog box.
    6. Click OK to close the Label Manager dialog box. The point features are labeled with the ArcGIS Pro annotations.
      An image of point features labeled with ArcGIS Pro annotations.
In ArcMap, the point feature labels can be converted to annotations. For more information, refer to ArcMap: Converting labels to annotation.
Related Information
Last Published: 11/26/2018
Article ID: 000017462
Software: ArcMap 10.5.1, 10.5
