HOW TO
Update ​enterprise geodatabase data sources for map documents using ArcPy
Last Published: September 28, 2021
Summary
There are numerous reasons why data sources need to be repaired or redirected to different locations, for example, migrating to a new machine. Manually updating every affected map document can be overwhelming. With the arcpy.mapping scripting environment, it is possible to automate data source updates for individual layers or all layers simultaneously in a common workspace without even having to open the map document.
Procedure
The following steps describe how to update an enterprise geodatabase data source using ArcPy:
  1. Import the necessary module and specify the map document location.
import arcpy
mxd = arcpy.mapping.MapDocument(r"mxd_source_location")
  1. Specify the new enterprise geodatabase data source path.
new_sdeworkspace_path = r"new_enterprise_source_location"
  1. Loop through the layers available in the map document and replace the old source to the new source specified in step 2.
for lyr in arcpy.mapping.ListLayers(mxd):
    print lyr.name
    lyr.replaceDataSource(new_sdeworkspace_path, "SDE_WORKSPACE")
  1. Save the map document.
mxd.saveACopy(r"save_location_path")
del mxd
The following shows a full script sample:
import arcpy
mxd = arcpy.mapping.MapDocument(r"E:\Data\Mxd\test\​old.mxd")
new_sdeworkspace_path = r"E:\Data\Connections\GISADMIN@GEODATA.sde"
    print lyr.name
mxd.saveACopy(r"E:\Data\Mxd\test\new.mxd")
del mxd
Article ID:000017448
Software:
  • ArcMap 10 6
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcMap 10 7
  • ArcGIS Pro 2 x
  • ArcMap 10 8
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
