PROBLEM
When creating a database view for a feature class in ArcMap, the SHAPE field data type is changed to long integer in the database view.
This issue occurs because the database view is created from a feature class with binary storage type. There are three tables in the geodatabase associated to the SHAPE field of the feature class. A database view does not recognize three-system tables and only reads one table, which is the business table. When creating a database view, the SHAPE field of the business table is read as a binary and converted to long integer.
For more information on geometry data types in ArcGIS, refer to: SQL Server data types supported in ArcGIS.
Use the Migrate Storage tool to change the geometry type from binary to geometry. For more information about the tool, refer to: Migrate Storage and Data migration from one storage type to another.
Note: The SDE user must connect to the geodatabase with database owner level privileges to run the tool.
Get help from ArcGIS experts
Download the Esri Support App
