ERROR
Can not download image: 'http:' because Invalid data provided
Last Published: May 5, 2022
Error Message
When attempting to publish a survey from the ArcGIS Survey123 website, the survey fails to be published and the following error message is returned (sic):
Error:
Can not download image: 'http:' because Invalid data provided.
An image of the error message.
Cause
This issue occurs when the Image option is enabled in the Survey Header section but there is no image used in the survey. This causes the survey to find an image URL that does not exist.
The Image option is enabled in the Survey Header.
Solution or Workaround
  1. In the ArcGIS Survey123 website, navigate to Design > Edit.
  2. In the Survey Header section, enable the Text option.
  3. Click Publish.
The Text option is enabled in the Survey Header section.
Article ID:000017313
Software:
  • ArcGIS Survey123 Website
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
