Frequently asked question
How do I download Navigator for ArcGIS without access to Google Play?
Last Published: September 22, 2025
If you don’t have access to Google Play and it is necessary to download the latest version of Navigator for ArcGIS to an Android device, Esri provides a setup that can be downloaded and installed on the device.
While downloading Navigator for ArcGIS from Google Play is the recommended method, it is also possible to download Navigator from Esri to a workstation and sideload it onto the mobile device.
  1. Download the setup file for Android.
  2. Run the .exe file, extracting the contents to your machine.
  3. Use the extracted files and your organization’s deployment system to deploy to your devices.
Article ID: 000017297
Software:
  • ArcGIS Navigator
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
