PROBLEM
When using the Calculate Field tool in a model, if the Calculate Field expression requires a model variable of type string. That model variable must be enclosed in quotes. For example, the following Calculate Field tool expressions convert a model variable (of type string) to uppercase:
VB: UCase("%StratumName%")
... and not UCase(%StratumName%)
Python : ("%StratumName%").upper()
... and not (%StratumName%).upper()
Without the quotes, the model fails. The illustration below shows an example model with relevant parameters:
The VBScript and Python expressions fail because the model convention of denoting model variables with surrounding '%' signs is not recognized in the model builder manner by the Calculate Field tool expression parser (the Python interpreter or the VBScript interpreter).
Given the above model illustration, there is:
a string variable named strIncoming (which has a value of 'abc')
Consequently, the parser searches for a variable named 'abc' and that variable's value to convert to uppercase. However, because it is unable to find the variable named 'abc', the model fails with an error results.
Modify the Calculate Field expression to enclose the string variable in quotes, for example :
Python: ("%StratumName%").upper()
Article ID: 000017185
Get help from ArcGIS experts
Start chatting now
