HOW TO
ArcGIS GeoAnalytics Server enables the configuration of the datetime field of a big data file share in the Data Store tab in ArcGIS Server Manager. The following is a common format:
yyyy-MM-ddTHH:mm:ss.SSSZ
The T and Z values are defined by the ISO 8601 standard, where the T parameter separates the date from the time-of-day, while the Z parameter is short for zero hour offset, also known as Zulu, representing UTC time. Since the datetime field is meant for numeric characters, if the above format is configured in the Big Data File Share window, the format is not properly read because T and Z are not numbers. So the ArcGIS GeoAnalytics Server tools return null values in the datetime field.
yyyy-MM-dd'T'HH:mm:ss.SSS'Z'
Article ID: 000017149
Get help from ArcGIS experts
Start chatting now
