PROBLEM
When a Story Map Cascade app is hosted on a web server, some fonts do not render correctly. For example, if text displays as the Open Sans font in an app built using ArcGIS Online, the same font is not recognized by the app hosted on a web server and displays as the Arial font instead.
This issue occurs due to the limitations of the configuration for supported fonts by the web server where the app is hosted and is not caused by the Cascading Style Sheet (CSS) behind the app UI.
In some instances, required extensions and Multipurpose Internet Mail Extension (MIME) types are not configured or added to the web server. These required extensions and associated MIME types can help to identify the types of content that can be added to a browser from a web server.
To resolve this problem, add the following extensions and associated MIME types to the Internet Information Services (IIS) Manager by doing the following:
.eot application/vnd.ms-fontobject .ttf application/octet-stream .svg image/svg+xml .woff application/font-woff .woff2 application/font-woff2
Get help from ArcGIS experts
Download the Esri Support App
