HOW TO
List hosted items and the REST endpoint URLs using ArcGIS API for Python
Last Published: July 20, 2023
Summary
Contents from a portal can be added to a different portal using ArcGIS API for Python with the add() function from the arcgis.gis.ContentManager module. Within the add() function, required parameters include the REST endpoint URL of the desired item. The REST endpoint URL is available in the following template:
http://<host name>/arcgis/rest/<ServiceName>
Retrieving the URL of all the items in a portal can be tedious when a large number of services is involved.
This article provides an automated process to retrieve the REST endpoint URLs of all feature layers or web maps in a portal using the arcgis.gis module.
Procedure
  1. Import the necessary modules.
import arcgis
from arcgis.gis import GIS
  1. Specify the user credentials and connect to the portal.
user = "username"
password = "password1"
url = "https://< a portal url >"
gis = GIS(url, user, password)
  1. Search and list all the feature layers available.
fcs = gis.content.search("owner:" + user, item_type="Feature Layer", max_items=10)
fcs
  1. Iterate through the list and return the REST URLs.
i=0
for list in fcs:
    print (fcs[i].url)
    i=i+1
Article ID:000016853
Software:
  • ArcGIS API for Python 1 x
  • ArcGIS Server
  • Portal for ArcGIS
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
