HOW TO
Changes to Business Analyst Desktop reports can be made by creating a custom template using the Fusion Report Designer. Different sections of existing report templates can be imported to the custom template. In some instances, it may be necessary to change the default logo and remove the subtitle, which displays the user's name in the report.
Note: Ensure the Esri Business Analyst Desktop 10.4 Online Report Editor Patch is installed to enable the Online Mode for the Fusion Report Designer. For more information regarding the patch, refer to Esri Business Analyst Desktop 10.4 Online Report Editor Patch.
Note: The size and appearance of the image can be adjusted to the desired specifications.
Get help from ArcGIS experts
Download the Esri Support App
