PROBLEM
ArcGIS Pro 2.0 undocked panes do not display properly in dual monitors
In some instances, when Windows 7 users undock a pane or window in ArcGIS Pro 2.0 and move it from one monitor to a secondary monitor, the pane or window is not displayed or drawn fully in the second monitor, as shown in the following image:
image of a feature table not properly drawn in a secondary monitor.
Cause
The Windows 7 system settings used for the appearance and performance are not configured properly.
Solution or Workaround
As long as the machine meets the graphical system requirements for ArcGIS Pro 2.0, Windows 7 can properly display the undocked panes or windows in a secondary monitor with the correct settings. Follow the steps below to configure to the proper appearance and performance setting in Windows 7 for ArcGIS Pro 2.0:
  1. Click the Start button.
  2. Click Control Panel > System > Advanced system settings.
  3. Click the Settings... button under the Performance section.
  4. Under the Visual Effects tab, check Let Windows choose what's best for my computer.
    User-added image
  5. Click Apply.
Once the new appearance and performance setting is applied, the undocked panes and windows are displayed or fully drawn in the secondary monitor.
Article ID:000016551
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
