ERROR
The domain is incompatible with the existing default value
Last Published: April 24, 2024
Error Message
After creating new domains and subtypes for a feature class, the following error is encountered when attempting to apply the new domain to a subtype.
Error:
The domain is incompatible with the existing default value.
However, the same domain and default value can be applied to other feature classes with the same schema.
Cause
The error may be due to the default value set for the field. The existing default value interferes with the domain applied by the user.
Solution or Workaround
Use one of the options below to resolve the error.
Reset the default value
  1. In the Catalog window, right-click the feature class > Properties.
  2. Click the Subtypes tab.
  3. Select the subtype in the Default Subtype drop-down list.
  4. Remove the values in the Default Value field for the respective field name and click Apply.
  5. Change the domain to the new domain name.
    Delete values in the Default Value field, select a domain in the Domain field.
  6. Set the default value in the Default Value field and click Apply > OK.
Remove the default values and create a new subtype
  2. Click the Fields tab and remove the default values listed for each field.
    Remove the default values listed for each field from the Fields tab.
  3. Create a new subtype and apply the default domains and values. For more information on how to create subtypes, refer to: ArcMap: Creating subtypes.
Article ID:000016329
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
