PROBLEM
ArcGIS Online and Portal for ArcGIS map viewers allow users to configure filters for layers based on a value, field, or unique values. Filtering based on unique values provides a drop-down list of all unique values returned by the server where the service is hosted. In some cases, when configuring filters for layers, the drop-down list is not populated.
When applying a filter, ArcGIS Online queries the server hosting the service to obtain all its necessary information. The responses from the server for the queries are based on the maxRecordCount parameter defined at the service level when publishing. By default, the maxRecordCount is set to 1000.
In some cases, the data may contain more unique values than the maxRecordCount defined in the service properties.
For example, if a service contains 3000 unique values and the maxRecordCount is not defined by the user, only the first 1000 unique values are returned.
Get help from ArcGIS experts
Download the Esri Support App
