PROBLEM
When accessing ArcGIS Insights from Portal for ArcGIS versions 10.6 and below, the following message is returned:
Error: You're about to be redirected to Portal... Sorry, you don't have permission to access Insights for ArcGIS. Contact your ArcGIS administrator for access privileges.
Note: The steps included in this article apply to ArcGIS Enterprise version 10.6.x and prior releases.
To resolve this issue, follow the instructions described below.
Note: Optionally, use the Search by drop-down option to filter and select the user. In this case, check the Level 2 button.
Article ID: 000016197
Get help from ArcGIS experts
Download the Esri Support App
