Frequently asked question
What is the difference between the Adjust 3D Z tool and the Feature to 3D by Attribute tool?
Answer
When z-values must be updated based on field values, there are two geoprocessing options to achieve this: The Adjust 3D Z tool, or the Feature To 3D By Attribute tool. Both tools allow z-values to be updated in a dataset. However, the methods of each tool are unique.
  • Adjust 3D Z
    The Adjust 3D Z tool adds or subtracts field values from the existing z-values. For example:
    Image of the Adjust 3D Z tool
    Image of the Adjust 3D Z tool output
  • Feature To 3D By Attribute
    The Feature To 3D By Attribute tool creates a new feature class with the field values as the z-values. This removes existing z-values from the dataset and repopulates them with the field values.
    Image of the Feature to 3D by Attribute tool
    Image of the comparison
    The Feature To 3D By Attribute tool requires a 3D Analyst license.
Article ID:000016136
Software:
  • ArcMap
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
