ERROR
Create Replica failed. DBMS table not found. The workspace is not connected
Error Message
When attempting to perform a geodata service replication, the following error is returned:
Error:
Create Replica failed. DBMS table not found. The workspace is not connected.
User-added image
Concurrently, a SEVERE level error is logged in the ArcGIS Server Manager indicating that the geodata service participating in the replication is the source of the error.
User-added image
Cause
This issue occurs when an alias is specified in the properties of the ArcSDE feature class. The replication process fails due to the difference between the ArcSDE feature class name and the layer name in the Table Of Contents (TOC) in ArcMap.
Ensure the layer names in the ArcMap Table Of Contents match the dataset names in the geodatabase. Refer to Step 2 in ArcGIS Server: Publishing a geodata service with a map service.
Solution or Workaround
To resolve this issue, refer to the instructions provided below:
  1. In ArcCatalog, right-click the desired feature class in the database connection > Properties.
      pro
  2. In Feature Class Properties, navigate to the General tab.
  3. Under Alias, remove all aliases, and click OK.
    Alias
  4. Republish the map service. For more information on publishing a geodata service, refer to ArcGIS Server: Publishing a geodata service.
Article ID:000015142
Software:
  • ArcMap
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
